Giali ? Heated Gear - connections??
Santa-2512
Omnipotent one
North Pole
I fould a load of heated gear in the garage at the weekend - ( i forgot i had this lol)
Its 2 socks, a pair of gloves, and a waistcoat
Its made by Giali - now Klan i believe
Each item of clothing comes with a 2x press stud type arrangement to connect the
power lead.
The power lead has a rocker type toggle power switch and an inline fuse
each terminates in a 2 wire PTF canbus plug (how fortuitous),
(Just looked online and it would appear i'm some leads missing - as the canbus type plug is to link each pair - the power supply is ring terminals )
However there are 5 sets of wires - ergo 5 plugs & leads
Should there have been a distribution type module that this lot would have gone into ?
or would have all 5 wired to male plugs and then direct to the battery ..
I cant find any inscructions online, and Giali / Klan no longer seem to be in business
any ideas
(i suppose i should power each up, and see if they actually work first lol) :)
It might help if you put some decent photographs in with your words. It'll help bods imagine what you are looking at.
Try these bods, too: http://klan-heated-clothing.com
Which will bring you to: http://klan-heated-clothing.com/product-category/klan/
As most full sets (jacket / vest, gloves, heated trousers and socks, along with their power supply and in-line temperature controller) wire up the same way, this might not be too far out:
As a long shot, this bod had some Giali / Klan gear. PM him to see if he can help:
http://www.ukgser.com/forums/showthread.php/129035-Giali-Klan-jacket-amp-gloves-polarity
