For Sale GIVI Trekker 52L Top Box and GIVI M5 Monokey mounting plate
andysdad
Northampton
Top box was new in February and is in excellent condition (one barely noticeable dimple on the right side, see photo).
Handcrafted liner (OK a bit of old underlay, but it does the job, see photo).
Three laser-cut keys – 2 x GIVI plus one other.
NB The Kappa version uses a conventional key, not a more-secure laser-cut one.
M5 Monokey mounting plate comes with all 6 blanking plugs, plus 4 nuts, washers and nyloc bolts.
The Trekker 52L Top box is £243.99 from SportsBikeWarehouse, the M5 Monokey mounting plate is £38.70, the spare key cost me £10, total £292.69
The dimple!
All this wonderment - the top box £175 and the mounting plate £25 - can be yours for £200 collected from Northampton, or meet within 30 miles or plus postage at cost (e.g. ParcelForce 24 Fully Insured for both is c.£23).
Please post on here then PM me.
Cheers.
Bump - slow market at the moment!
Which bike(s) does the adapter plate fit? Or is it part of a bigger pannier rack? Looking for a box for my 2011 1200 Twin Cam
The M5 plate should be used with Givi SR684 mounting kit which is £90 at sportsbike shop
https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/207042
but includes the M5 plate as well, not sure if you can buy just the metal support bars/plates separately or not.
I'm pretty sure I have those parts somewhere if you need them to fit the box/plate for sale here, fitted for many years on my '05 GS1200
Thanks for the information.
I think I will hold out for a Vario top box. I don't need it until March, so I have time.
To the OP - good luck with the sale
GlynnJ - yes the Givi M5 came with the specific Givi rack for my bike, but any flat plate could be drilled to match, then the flat plate mounted on an existing rack. Or simply drill the holes to mount the plate direct if the rack is suitable.
I removed the Givi to fit a Hepco & Becker plate (I drilled the Givi rack baseplate to match the H&B plate) as I already have 2 H&B top boxes for another bike. Made no sense to keep 3 top boxes/2 systems!
Winter obviously not the best time to sell, but ever-hopeful!
Winter is over, Spring beckons, and touring will start.
Roll-up, roll-up, roll-up - LUGGAGE FOR SALE!
Might re-write this ad as it's had more bumps than dodgem.....
More bumps than typical Northamptonshire road….
(Almost) as-new topbox for 25% off.
Anniversary bump - it's been a year!
Topbox and plate, £210 posted mainland UK.
