numpty question alert!!
Whats the benifit of the Hagon shock over the original?
Nice bike by the way
Richie![]()
The Air shock is not very good off road
Richie![]()
wow, BMW done their homework again
Thanks for the reply and keep us updated![]()
hi dibdob
have you got any plans for the old levers you've taken off?
roll on Friday my next day off
It's not that bad and you do get used to it, same as HP2e
The faster you go............. the better it is
XC's handle fine and the airshock is a lot lighter than a conventional spring unit
The only time you really notice the airshock is on tight,nadgery rocky going where you have to slow down
How did the HAGON shock perform, i havnt had any issues with my air shock as yet but its worth bearing the Hagon shock in mind, you said it was £275 , is that right all other posts people seem to be talking £500 plus for a replacement shock?
Also sorry to be a pain but where did you get the shock from? and what was its availability?
thanks ferret![]()
but as i intend to do most of the Rallies this year i don't fancy messing about with the air bag Thanks for that, hope to be doing some of the rallies again this year, did the radnor forrest, cambrian and hafren last year, didnt do too bad but hope to do better this year
Maybe see you at some, as you pass me of course![]()
Right the story so far, I have received a frame guard (you only get one)and a replacement steel gear leaver for a KX60.
Today i popped into my local off road shop, bought some extra heavy duty tubes, a bottle of slime and a rear rim lock (i don't bother with a front as i always get punctures right were its fitted) I also managed to scrounge an old pair of MT21's for nothing, They will do till the first rally comes along
I have ordered a Scorpion Exhaust, a BMW Headlight Guard and 14 tooth front sprocket.
Next up i need the replace the clutch and front brake leavers, as the chap i bought the bike of cut the balls ends of so the handguards would fit. Then i going to try and make a sump guard, I think the £180 Touratech want is a bit over priced, Then sort out the rear end with some smaller indicators and fabricate some sort of tail tidy.
I will be fitting some wider bars and some bar risers i have spare the back of the garage.
I think I'm going to replace the rear Air shock for a HAGON unit, at £275 it sounds like a good deal![]()
dibdob which f650 brake lever did you get from wemoto that fits the xchallenge ?
cheers
