I sent an Email to Hagon shocks today and this was the reply i receaved
Hello Mark and thank you for your enquiry,
We can supply a replacement for the G650X , please confirm you have a frame prefix of WB1016. See below for details.
The Hagon monoshock for your bike is £275.00 including vat and free UK delivery except Northern Ireland, which incurs a £15.00 surcharge.
Our Hagon shock has adjustment for pre load as well as compression and rebound damping linked on a single adjuster.
It comes complete with all tools for adjustment and fitting instructions.
The Hagon shock is guaranteed for 2 years and is fully rebuildable.
We can also supply custom built Hagon monoshocks including seat lowering options, you can specify reductions in your seat height in 10mm increments from standard to a maximum of 50mm.
Please state proportion of solo/pillion/luggage use and weights of rider(s) when ordering.
If you choose the bigger reductions you may need to modify your side stand as the bike will not lean sufficiently for stable parking it will also be more difficult to lift the bike onto it’s centre stand.
We can also custom build for heavy rider & pillion, Light solo only, harder and softer springs. £325.00 including vat.
Many of our Hagon monoshocks can be supplied with the added convenience of our Hagon hydraulic preload adjuster at a cost of an additional £125.00 including vat. This is a great benefit if you are touring.
We can also supply Hagon fork springs for your bike at £67.50 including oil and fitting instructions. Our progressive spring kits are designed to retain a comfortable ride at the top of the fork travel while offering superior control under hard braking.
We accept all major credit/ debit cards.
Regards
Hagon Sales Team
7 Roebuck Road
Hainault Business Park
Hainault, Essex
IG6 3JH
Phone 0208 502 6222 Fax 0208 502 6274
Mon-Fri 9.00am to 5.30pm Sat 9.00am to 1.00pm
