Green Laner
I feel no shame in modifying non gs frames. If a use is not found for them they end up as scrap and are lost for ever.
This project seems as gooder reason as any to cut those hideous lumps of steel off.
Seems to me it will be a G/S in all but the frame designation.
Keeping on with the theme of working with what you have - I fitted an R80ST tachometer and warning light set up, into the G/S speedometer housing.
Thinking I probably don’t need to know my speed when I’m green laning 😉
Considering my options for a mini speedo where the warning lights would normally live.
Think I have a km g/s speedo,
And the idiot light lenses,can prob come up with the printed circuit/ bulb holder( may need some work)
Also got a headlamp but no metal rings( LHD)
Thanks Mikey
I do already have 80% of the G/S headlight parts including a RHD Bosch lens but missing the all important bracket circled..
I know these are hard to find but i’m no rush.
Will be in touch
Pete
As i said before…I have the warning lights panel with working lamps if you want it.
Then you could fit Mikeys kmph speedo……
