I guess I found the problem. called to a friend of mine who is an expert on the CAN BUS system. First thing he asked was, what navigator do you have on the bike? I told that I have a garmin, he asked that is it a type of garmin which has a separate transformer on it. I told him yes there is a box between battery cable and plug for the navi. He told that here in Finland they had lot's of problems with taxi's where a certain type of garmin navi was installed, and all of those navigators where a type with transformer to decrease voltage from 12 volts to something lower. In my zumo 220 is a similar system. This system is poison for vehicles with CAN BUS system because even when you switch off eletricity completely from the circuit so this transformer still goes on, and even when the current is low so it leaves the CAN system activated and drains the battery,,,
So now I took off the navi fuse and tomorrow we'll se again that was this problem solved...
