This is a GSA Yes? There is no choke is there? - just a fast idle, just like keeping the throttle slightly open. It sounds to me (numpty mode on!) like a very bad earth. The starter draws a lot of current doesn't it? Might explain the cutting out mid ride too - unless you had the alarm fitted at that stage in which case it might have had something to do with it. I think the earth for the starter runs straight to the earth strap on the block (though I could be wrong), under the battery tray. If you look under the tray you should see (if it's like mine - I changed the loom last weekend
) the earth strap bolted to the block. It's a bitch to get at! You could try running another earth from the starter direct to the battery to see if that changes anything. I'm not sure of the circuitry round the starter though
