30mm lower chassis either end. This comes from the handbook:-
Running gear
Front wheel
Type of front suspension BMW Telelever, with anti-dive top fork bridge,
leading link pivot-mounted on engine and telescopic
forks, central spring strut supported by
leading link and frame
Design of front wheel suspension Central shock absorber with helical spring
with Dynamic ESA OE Central shock absorber complete with torsion
spring and header tank, electrically adjustable decompression
and compression-stage damping
Spring travel, front 190 mm, at wheel
with lowered suspension OE 160 mm, at wheel
10
167
z
Technical data
Rear wheel
Type of rear suspension Cast-aluminium single swinging arm with BMW
Motorrad Paralever
Type of rear suspension Central shock absorber complete with torsion
spring, adjustable rebound-stage damping and
spring preload
and compression-stage damping,
electrically adjustable spring preload
Spring travel at rear wheel 200 mm
with lowered suspension OE 170 mm
10
168
z
