Handle Bar Adjustment
Bob1150GS said:
Well I only work part time now that I am retired. I used to do 25 hours a day. Anybody beat that!
You were lucky, I had to lick t'road clean and pay mill owner for t'privilege of work. :thumb
seeing as nobody has actually answered the question - allow me.
The ends of the 'bars are rubber mounted in a sleeve between the main bar section and the outer. The welded bracket on each part stops the outer part from possible rotation on the rubber mounting sleeve.
For bar adjustments of any kind - ignore it.
PS i carefully straghtened my bent 'bars with a long length of scaffold pipe as well. Amazing what leverage can do :D
pps - its screw 8 as already pointed out - that lets the switch gear rotate.
Bob1150GS,
Remove the nut underneath which attaches the mirror. Then remove the mirror by lifting upwards.
Undernesth the switchgear nearest the clocks you will see a cover that is fixed by two screws, remove these screws and lift away cover.
Next there is a screw undernesth where the cover was and another at the back of each resevoir, remove these and the switch gear will come appart.
You can now gain access to the clamping screw, by losening this you will be able to set your grips to any angle.
The whole process from start to finish took me about 20 mins, 'baring' any problems - 'baring' - do you get, see what I did with that - ha ha ha !!!!!!
Any further questions please feel free to pm me.
Thanks Teddy I would never have found the two hidden screws without your input.
Total job including finr tuning about 15 mins.
