Happiness is
Full service, valve clearances checked, didn't need doing, brake fluid changed ... ready to rock'n roll :D
Hyperpro 40mm lower spring..
2 plastic bungs added, simple but just finishs it off.
17 tooth front sprocket fitted to reduce revs in top gear
2 X 35mm plastic bungs : eBay no - 221817431048
Fitted the hella/din/Bosch 12v plug..
A tad fiddly with my hands.
Many thanks to John, for the pictures of the plug/wire location on XC..
Also wired another Hella/Bosch/Din plug direct to the battery with online fuse.
To charge phone /Scala Bluetooth headset. To safe having the ignition on..
Added an extra cable tie as 2 wasn't enough...
Hi Ash,
Where did you get the extra socket?
Cheers,
Ian.
PS are you adding sleeving around the wires to the battery?
I put mine here ...
Ideal for heated jacket or trickle charging when under the cover :D
Hi Ash,
Cheers,
Ian.
eBay no : 251607020957
No sleeving just cable tie together... You only see a tiny bit of cable..
:thumb
Cheers. I have the OEM socket, but may need an extra one.
I wanted a constant live, not via ignition.
If I'm out all day using my MPV player on my garmin 395LM into my helmet via my Scala it goes flat especially if garmin is routing as well.
So i wanted the capability of charging without ignition on..
:thumb
Not bad fuel consumption, considering I was cruising on make A & B roads with a couple of short dual carriageways.
Between 50 - 80 MPH
:thumb
Re post b4 this one, day bimbling to West Bay in my native birth county of Dorsetshire...
Cracking day on the XC..
:thumb
Happiness is ...
The 'Big Breakfast' breakfast run yesterday :D
