Gazzza
My bike was serviced by a BMW dealer a month ago and it has been stood in my garage ever since (apart from riding it home from the dealer’s I haven’t used it). This morning I took the bike onto the drive and started the engine. It sounded a bit "knocky" initially (for about 2 seconds) but then sounded normal after a few seconds of running (in fact it usually does this so I didn’t think anything of it). I left it running for about 10 minutes before switching it off. A few hours later (bike still on drive) I noticed a pool of what I thought was water on the drive under the sump. It wasn’t water it was oil (nice clean oil which resembled water on first seeing it). I checked the oil level window and it was empty. I went back into my garage where the bike had been sat for the last month and the carpet under the bike was absolutely saturated with oil. It had clearly been dripping down from around the oil filter, down the centre stand legs and onto the carpet. I haven’t investigated properly yet as I had to rush back to work but it seems to be coming from around the oil filter. I have a feeling that it wasn’t tightened properly by the mechanic when he serviced it. My worry is that I have run the engine for about 10 mins with very little or no oil at all. Is this likely to have damaged the engine?
Any advice greatly received
Gaz
Gaz
