Headlight woes
g.s.john
Getting old aint fer pussies
slade green kent
The height adjuster has stripped the thread hardly surprising metal screw engaging in threaded plastic but the load lever is still working it moves the reflector approx 5-6mm.
so i bit the bullet and got a new headlight from James Sherlock the adjuster and load lever are not connected to the reflector as far as i can see the ball and socket are engaged but the reflector has about 10mm of free movement.
A new unit should work out of the box is there anything i should be doing before fitting to make it work before i send it back to Sherlock for exchange?
It's a ball and socket type thing so you should be able to click it back together. Or just send it back since you paid good money. Whatever is the least hassle for you I guess.
