hovis
Hi all, I have a bit of a problem with the 11Gs.....took it for a run today,the first for about 6-8 weeks.Anyhow the bike was running fine until I turned on the heated grips..........about 2 mins after they were switched on the throttle started sticking open and had to be physically closed ....I turned off the grips and a couple of minutes later the throttle freed off again ..I tried again 3 or 4 times and the same thing happens .....also checked the temp of the grips and they dont seem to be heating very well if at all.....Does anyone have an idea what the problem might be(the bike is still under warranty so hopefully it will be covered)
