Heated grips
madmax
Blackpool, England
2006 R1200GSA with OEM heated grips.
Over the last few months when using heated grips it has become noticeable that the throttle is becoming stiff to use, switch them off and as they cool down everything returns to normal.
Has anyone else had this problem, is it just a case of strip down and a re-lube.
Thank you
Regards
Martyn
Common problem.
Choose either option...
1. Undo right hand switchgear and move it left a little bit.
Or
2. Undo bar end wight, remove it then insert. Washer between bar end and end of bars.
Job done:thumb
Swelling grip caused by heat catches on bar end, that's all.
Roger.
Or
Job done:thumb
Roger.
Thank you for that info I will give it a go at the weekend.
Regards
Martyn
:thumb2
Failing that get a pair of Gerbing heated gloves, not the best thing since sliced bread, but certainly the first ever bread toaster,
I ride 363 days,.................Gerbings...........sorted
