Nah, doesn't take long to see that your forte is shoveling shite!
Jim![]()
Shovelling facts
Jim![]()
My multistrada heated grips work ACE!!!![]()
Was out on my '15 GS to-day. Temperature 7C. Hot was too hot to the point of scalding. Low was just too warm and needed to keep turning on and off. Maybe older colder grips were better - for me anyway!
There's the problem - no doubt in 2016 when BMW fit an infinitely variable heat switch instead of a 2 position switch all the 2015 owners will be saying their grips are not fit for purpose as well
Still happy with my 2014 after the forced software upgrade![]()
I wonder why BMW never went that way in all seriousness, tradition? I remember my 1100GS just had Low and High, my Tiger 1050 was the same, two position but aftermarket grips often have a rheostat or in the case of the R&G cheap'ies a 5 position setting. It' would not be quite as integrated I guess, but the switch itself on the bar could be a roller switch. (just thinking out loud here)
When BMW upgrade anything on a bike its always published for the sake of Marketing etc ..wonder why they just changed the grips last year with out saying anything ?
My guess is that BMW do use PWM as this is the most efficient and simplest way to do it (an oscilloscope would show this). On the 2015 grips (that probably get too hot even on the low setting in mildly cold weather) BMW could probably change the software to provide three, four or five levels of heat by successive pressing of the button. The problem is how to display it on the current display as there are only two dots and they are not about to design a new display with more dots for this minor change.
One possibility would be to have three levels, they can show the heated grip symbol for low, the heated grip symbol plus one dot for medium and the heated grip symbol plus two dots for high. It depends whether the current display can show the grip symbol without one dot.
BMW, you can have this idea for free!
The reason that there is confusion about fitting the higher power grips to the 2014 models is because the electronics don't use fuses but instead measure the current drawn by a device and switch it off if it draws too much so the wiring doesn't melt. The current limit for the grips will have been designed with some tolerance but when you fit the higher power grips the current will be higher and will come close to the maximum allowed. In certain circumstances, due to grip resistance manufacturing tolerance, temperature etc. the 2015 grips might exceed the maximum current allowed on the 2014 electronics and trip the protection. The problem for BMW is that if they sanction fitting the new grips to the older bikes, the manufacturing variations may mean some bikes trip the limits sometimes and then the owners complain that their new grips stop working setting off another 20 page thread. That's why it will be remain a try it for yourself situation.
I am glad that someone understands!
I am currently using FET automotive switches in a new power supply design, they have a monitor output that provides a current in proportion to the load current (FET current mirror). I have added an A/D so that I can adjust the current limit and turn the switch on and off under firmware control but this adds to the cost. I don't know but guess BMW want to keep costs down so perhaps they chose a simpler systems with fixed limits, if they have done then it MIGHT cause issues under corner cases if the grips are changed for higher current ones as explained by the GS_or_Bust above.
What you are all saying about PWM control is probably correct and there is the possibility that the higher power grips may reach the limits defined on the early 13/14 bikes, BUT there is also a good chance that BMW wiring and firmware can support the higher power grips of the later 14/15 bikes. I know BMW have uprated the grips but Id be surprised if they actually had to have a new wiring loom with larger wires as well!
Ian
