Heavy clutch-cable lube
ssray
Stourbridge
Tried this the other day, usual thing is lever off, lube thing on the end and squirt stuff down it
I took the lever off but there was not enough freeplay to unhook it out of the lever perch
What am I doing wrong?
Ta Ray
Presuming the cabled clutch is similar to other bikes, take the pivot pin/bolt off that the secures the lever, that will make it easier.
My understanding, and it is very limited is that the clutch cable was self lubricating; if you feel it needs lubricating then you probably need a new cable.
