1Rider
Guilty
Okey, I stand corrected
Removed the front tire the other day (well actually just broke the bead on the side with the leak). Found out I had not cleaned the bead area properly
Eg I found very small bits/part of old grass where things should seal along the bead
Cleaned, added a small amount of lube. Pumped it back up. Now a handful of day later and no problem so far
All I can say in my defense is, I have not done/experienced this/to this extent with other (more flexible) tires. That said, take your time and do the job properly by the book, and you will most likely stay out of trouble
