I did this with my T Max . I got the wrong Fuel Doctor out and he siphoned all the fuel off , filled it with Shell V and off I went . Cost me £170 though !
Didn't know until it coughed spluttered 5 miles down the road, then looked at receipt, pulled into next station & filled up with diesel, 100K later car was still going strong.
Wow - that's some mileage on a single tank of fuel!! You must have happened upon the magic petrol/diesel ratio that provides near infinite economy![]()
Lake District with also took in the infamous Hardknott Pass....
Available to all just buy a French diesel infortunately they no longer produce the 1.9td which was one of the best diesels ever produced
Indeed.
Shame about the cars built around it.
Our Citroen was scrapped at 8yrs old.
I just had this same experience and this post is the correct solution. I did it with my 1250 GSA. Remove injectors then remove fuel line and flush.
These people in this thread have no idea what they are talking about.
Lift the bike up and take the fuel tank lid off.
Turn the bike upside down and give it a really good shake until all the nasty stuff comes out.
Then turn it back up the right way, kiss it better and you will be fine to go.
.....Ive done it to a KTM, wasn't a problem.....
This is what I did to start with but as the fuel lines to the injectors are still full of diesel the bike will not start. On the older bikes just cycling the ignition would have flushed the fuel lines but the 1250 does not have a return line.Can't you just use a jiggle hose, extract what you can, refill with petrol and ride it through?
Thanks for the update. So I'm presuming then you started your engine after the cross-fuelling? which then blocked the injectors and stopped the bike.
Would this still have happened if you'd not started your engine, but jiggle hosed as much of it out the tank, then refilled immediately with petrol before starting the engine?
