Help ! Fuel pissing out ....
Nope, I don't mention breather pipes anywhere. it doesn't matter where you remove them from as it makes no difference to anything. In fact you can leave them off at the tank flange and won't make any difference.
So, What difference does it make that i disconected the hose at the flange ?:confused:
One difference i can see is that you can disconect the hoses before lifting the tank. Is it just that?
Looking forward to my new QD conectors :thumb2
I can't work out how you managed to get the tank off first to disconnect the fuel pipes at the pump housing.
You remove the flexible fuel hose where it joins the soild plastic pipe, and then remove the tank.
My tank lifts straight up; I lay a towel on the right cylinder and rest the tank on there. Unfasten the jubilee clips and off.
I can see now looking at it, that it would be simpler to disconnect where you suggest. Oh hum, we learn, but now with my new QD connectors this is past.
