Help please with a bit of wiring please
slimpickings
Doncaster
Can anyone tell me where to connect the yellow and black wires ?
Are you wanting them on with the high beam or all the time
Personally I would wire them to the side lamps circuit Yellow should go to the grey with a black trace and the black is the ground
You then control them with the switch if the sidelamps are on This also helps setting up camp as you can have them on while you have the parking lights on ;)
if you are wanting them on with the high beam? Just connect the yellow to the high beam positive feed
I would say the black is an earth and the yellow a switched live. I've only just got my 1200 so am not that familair with the canbus system but you may need a HEZ ezCAN setup.
I fecked the switch off, and wired into my dipped beam
Or get a cansmart and feck the switch off again
