Here's a good electrical problem
Steptoe
Him/Bloke/Fella.
S/W London.
An 1150GS completely dead. No instrument lights, no side lights, absolutely nothing.
Battery has 12 full fat volts and terminals all tight.
Ignition switch wiring loom is all tickety boo.
Relays and fuses all OK.
I'll be "going in" later today....
Still measuring 12v at the battery when the ignition switched on?
Fractured terminal post inside the battery, will still measure 12v with a meter but as soon as you draw ANY current, then nothing
I had that problem but on a series 1 Cosworth .....
It turned out to be an old immobiliser that I didn't know was there .....
Some halfwit had by passed it badly with scotch locks .... :blast
Thinking some more There's a few more things it could be
Contacts burned in ign switch
Load shedding relay
But one things for sure
It's in the right place for it to get fixed :-D
Look forward to a report of findings so I can file it in my "bits of useful info" file
:rob
Is the battery chinese? Some of their volts are not made to european standards and get stuck in the wire at bends, because the counterfeit volts are bigger and not as smooth as ours.
Sucking-out the blockage using reverse polarity never works, so a new harness is the only solution.
Their Amps are even worse. Totally wrong shape, and clog-up alternator regulators.
You can clear them out with a magnet if your lucky.
And their Ohms are made out of bamboo and cow shite.....;)
Have you gone in??? Do we need to send a search party to bring you out :D
Battery fine. All relays fine. Ignition switch fine. All earths fine.
No power reaching ignition circuit.
A Broken wire somewhere in the badly decomposing loom.
So i bypassed the loom and added a live circuit to power the ignition. :thumb2
Job done. Never had a bike in showing the symptoms this one had. :beerjug:
How old is the bike? Can you seen signs of the decomposition then? Sounds like its going to need a new loom soon.
Fecking electrics - I hate them. Demon infested rats nests.
Had something very similar on an old bike I had. Checked the loom, switches everything, after a about 3 hours I was about to give up when I found this.
Ooops sorry forgot the photo.......
