Hex GS-911 and Battery Voltage
K9Morris
North East - Washington
I've just bought a GS-911 to use with a 2021 1250 GSA. When I connect it to scan etc after a few minutes it says the battery voltage has dropped below 12.5 and service functions can't be done. The battery has always been on a conditioner, shows green on the conditioner (charged), stays plugged in alongside the GS-911 and the bike cranks over fine every time and starts first time even when it hasn't been used for a while. I've used this conditioner on previous bikes and never had a problem. Has anyone else experienced this voltage drop, particularly when using the GS-911 or anyone with electrical experience to offer advice please.
Mine is the same (2021 1250GSA)
So I just run the bike and do what I need to do. Even plugged into the optimate, the 911 complains about battery voltage. Even turn all the lights off etc..
You need at least a 5 amp charger, preferably smart charger or dedicated power supply, to maintain the bike battery voltage above 12.5v while it is powered up, but not running. Turning off accessories such as aux riding lights also helps. I use a NOCO Genius 5 charger and have no issues with the bike maintaining around 12.8v, providing the charger is switched on after the bike is powered up.
I used to get this all the time when I had the standard battery as supplied with a new bike. Since changing to the hybrid Motobatt, no such problems.
Do you have that battery model code please?
Yep, just about everyone gets the same battery warning and then you can’t run through the settings you’d like to do with the 911. I have a battery jump pack bought cheaply from Temu or somewhere like that and I just connect that to the battery leads and lets me work away on the 911 app as long as I need, no harm having a jumper pack with you on trips anyway as it’s a good backup in case of battery issues or hot starting issues.
As said above - just run the motor whilst using the 911.
According to Google Gemini....
The decision by HEX Innovate to set the voltage threshold at 12.5V for coding and service functions with the GS-911 is primarily a safeguard to ensure data integrity and prevent control module failure.
When you are "coding" a motorcycle, you are essentially writing data to the EEPROM (Electrically Erasable Programmable Read-Only Memory) of a control unit, such as the Engine Management (BMS) or the Central Vehicle Electronics (ZFE/BCM). This process is highly sensitive to power fluctuations.
1. Stability of the Communication Bridge​
During a coding sequence, the GS-911 acts as a bridge between your PC and the bike's CAN bus or LIN bus systems. If the voltage drops too low during the "write" phase, the communication can timing out or fail mid-stream. This often results in a "bricked" module—a state where the controller is stuck in a bootloader mode and can no longer communicate, often requiring expensive dealer replacement or specialized bench-flashing to recover.
2. Solenoid and Pump Draw​
Many service functions—like bleeding the ABS pump or recalibrating an electronic suspension unit—require the GS-911 to actuate mechanical components. These components draw significant current.
  • A resting battery might show 12.0V, but the moment the ABS pump kicks in, the high current draw can cause a "voltage sag."
  • If the voltage sags below the module's operating threshold (typically around 10.5V–11V), the module may reset during the procedure.
3. The 12.5V "Safety Margin"​
A fully charged lead-acid or AGM battery typically rests at approximately 12.6V to 12.8V. By setting the floor at 12.5V, HEX Innovate ensures that:
  • The battery is at near-full capacity.
  • There is enough "headroom" to handle the minor draws of the ignition and fuel pump being active during the diagnostic session.
Pro-Tip for Stable Coding​
If your GS-911 is blocking a function due to low voltage, the best practice is to connect a battery tender or charger (capable of at least 5-10 Amps) while performing the work.
[!IMPORTANT] Avoid performing coding while the engine is running to boost voltage unless specifically instructed by the software. The electrical "noise" from the alternator and ignition coils can sometimes interfere with the diagnostic signal.
The standard battery has borderline capacity. Best change it to the above motobatt, or a yuasa ytx20. Loads of overhead and enough cranking power to stop it banging back againt the starter clutch and destroying it eventually.
Same for me. I fitted a Motobatt Hybrid to my 1200RT today. I had to reset the service light which had come on after I connected the new battery, plugged in the GS-911 reset the service light and checked for faults. I found that the voltage stayed above 12.5V (in fact the lowest it dropped to was 12.9V).
You can feel the difference when you start up, standard battery kind of labours, even from new. Once the Hybrid is fitted it always starts with more guts.
Absolutely. I couldn't believe the difference of how quick the bike turned over and fired up.
