Nonkey007
I have a 2009 R1200GSA low miles at approx 18.5k owned 3 years with no issues, serviced around 80 miles ago, minor, plugs,oil,oil filter and air filter. Took bike out for a 50 mile ride after service all good. Added Seafoam as read on another forum,it was good for cleaning I injectors etc, again took bike out for around 20 miles, felt a bit perkier. Unfortunately fell ill and didn't go near bike for 2.5 weeks, started it up left it on tick over for approx 10 mins and it died, battery went flat trying to start,this happened 2or 3 times, got advice on another forum,stating that seafoam can draw moisture in the tank and form a film, so topped up with fuel, fully charged battery and she fired up fine, so I thought, started up again running up to temp and got iol on message, then thought engine started making knocking noise, looked in inspection window and it was full while running? Again read it might be overfull,although did 4 ltrs ,with filter? Drained a bit off ,so lower end of the window,topped up to 2/3 rds on the window,started and checked,oil drained from inspection window, YES !! all good, but after 15 mins of running up to temp, engine became noisy and window filled up with oil again whilst running,no warning lights on dash, no faults on moto scan,baffled
