Hp2 e,fighting me all the way
mikeyboy
S.M.T.R. Craigellachi,Banffshire
You come to the party a bit late ,but heyho,I know we all like pics:D
What started out as a service soon turned to shit.:blast
The bike had had a hard life,so it was decided that we would fit a new clutch.
However the bike wanted to put up a fight and two of the m12 subframe bolts sheared when trying to remove them.
After much pondering I decided it best to remove the motor to enable the engine to be split to MILL the sheared bolts out.
This may seem drastic but any mistakes removing the bolts would end up with a scrapped engine.:comfort
Things got worse when the front frame section securing bolt which passes all of the way through the motor was also stuck solid,so we had to jack the frame apart slightly and cut the bolt to allow engine removal:eek:
Here is our start point.
The short engine is rebuilt,all was good inside,
R/h engine side rebuilt,with new rings etc,just waiting on l/h cylinder head coming back from Chris,aka mistacat as the exhaust studs snapped on removal so they needed machining as well.
Hmmm
Sign of things to come
Get the idea where we are going with this:blast:P
Lower shock bolt was bent,
Sufficiently that it wouldn’t come out:comfort
Swing arm trunnions and bearings are bollicxed
...Fantastic to see mikeyboy, now concerned mine will need similar attention:blast.....
......keep the pics and info coming:thumb2
