i like this section..its like how it used to be
I'm with you here....I head straight here first... It's better than the pub.. The banter is mixed with tech support and great knowledge with out any complications... It's a great part of the forum.
And stupid questions get the piss taken and answered all at the same time without the poster or any other lilly livered twats being offended.
Just how fecking good is that. :thumb2
But i do worry about my belt, not a lot, just a little bit now and again. :D
I like it here as well. It gives me a warm fuzzy feeling – apart from the fact that Steptoe won't stop banging on about his poxy belt! :D
Do you think my belt is alright, did it look ok when you were riding behind on sunday, did you notice anything untoward.
What about the pulleys, DaveG mentioned the pulleys on sunday, i hadn't thought about the pulleys. Do pulleys break, do pulleys stop working. What's with the pulley problems. Have i spelt pulley correctly.
Well, it's funny you should mention – it's just that – you know when you got a way ahead of me? That was actually because when I was closer to your backend (fnurk), your belt looked like it was about to jump off the pulleys and fly off at me so I held back half a mile. Oh and have you got some kind of fancy fully floating pulleys on because they wobble about like fuck! I was going to tell you, but after a little deliberation, I got my camera out instead! :D
As an aside, maybe at Le Hog we should have a 'drive belt conversation veto'. Otherwise we are going to spend 4 bloody days talking about nothing else and giving it "Well have a look at mine, see what you think, I think loose is better, no I think tight is better, do you think mine is too tight though? I am a little worried!" We will all be gibbering wrecks by the end of it.
Matey boy up here said... "have you considered switching to a chain-drive conversion? It'll handle a fatter rear end".....
.....when he'd finished picking up his teeth...he mumbled something about tyre sizes ?:nenau
I think i've just found the problem. I call it a "belt drive", and i notice you've called it a "drive belt".
That's made me feel sooooo much better. We've been at cross purposes all this time.
I'll now be full of confidence when i head off into the wilderness of new malden.
Confidence in New Malden? You're a braver man than me. I won't go near there since it all kicked off with the Koreans!
surely this place is full of MT fans as you're the only Cnuts who can afford a Harley :hide
Hat Coat Door Slam!!!!!!!!!!!!!!!!!!:aidan
You're joking, most in here have got right old shitters with engines falling out, belts snapping on a daily basis and exhausts that all need welding up.
Wait for me, I'll just get my coat!!!!!!!!!!!!
:D:D:D:D:D:D
... and now i've taken to lurking in here. :hide
that's it fucked now. :blast
But just a tad cleaky i find:rob
Could you make a suggestion how it could be made less cliquey. My suggestion would be join in more then. If you stand on the sidelines, no bugger is going to pull you into a conversation. Barge your way in dammit man. Post more, moan less. Be rude to a few people :D
