I need advice for a route please
DrFarkoff
Grumpy Ole Git!!!
Islandmagee, Co Antrim NI
I have another funeral to attend in a fortnight at Exeter Crematorium
I am thinking early boat from Dublin and then a ride down avoiding the repetitive drudge of the motorway on a 35 year old motorcycle
AM I thinking that this is a reasonable road and could do it on 8 hours ish?? it says 6 hrs 06 on Google
Holyhead
Betws-y-Coed
LlanDindrod Wells
Raglan
and across estuary on the M4 and on down to Tiverton ??
https://goo.gl/maps/XdwZGz2mZYgMqt4S8
<iframe src="https://www.google.com/maps/embed?pb=!1m40!1m12!1m3!1d2510458.3770270343!2d-5.877854506274286!3d52.08665598669676!2m3!1f0!2f0!3f0!3m2!1i1024!2i768!4f13.1!4m25!3e0!4m5!1s0x48643537b6d29115%3A0x8c44937f42920c07!2sPort+of+Holyhead%2C+Holyhead+LL65+1DJ!3m2!1d53.3092687!2d-4.6289053!4m5!1s0x48651463227a6575%3A0x2afbefd48524751d!2sBetws-y-Coed!3m2!1d53.0930858!2d-3.8010354!4m5!1s0x486fc1098b8f0e87%3A0x9c7231e7dfce5ebb!2sLlandrindod+Wells!3m2!1d52.241699999999994!2d-3.377742!4m5!1s0x486d931370a51f8f%3A0x1e30820400ba441e!2sTiverton!3m2!1d50.902049!2d-3.4912069999999997!5e0!3m2!1sen!2suk!4v1559484511947!5m2!1sen!2suk" width="600" height="450" frameborder="0" style="border:0" allowfullscreen></iframe>
As soon as you join the A30 from the M5 come off at the the next junction and ride across Dartmoor to Tiverton
Sometimes its not easy to confuse a paddy "but" in this instance
Our group will likely be coming along the M5 and then off into Tiverton
Is Dartmoor not the bit over towards Proff's area ???
I’m guessing that alcohol or old age caused the confusion between Tiverton and Tavistock ...
good route down from Holyhead capel curig etc ,llandrindod wells all good areas .....is it no better for you to get the Fishguard ferry from Rosslare ?
Cwmystwyth mountain road aka national cycle route 81
https://www.google.co.uk/maps/dir/Devil's+Bridge+Falls/Rhayader/@52.3087001,-3.740499,11.39z/data=!4m15!4m14!1m5!1m1!1s0x486f998c23f3aee5:0x3392aeb9a3e40291!2m2!1d-3.8497637!2d52.3769323!1m5!1m1!1s0x486f955b89eec84f:0x50d8b23d498d100!2m2!1d-3.510641!2d52.301537!3e0!5i1?authuser=1
This will put you onto the A470, a nice trip under Pen y Fan. I would then suggest Monmouth to Chepstow via the Wye Valley and Tintern Abbey but I think the road is closed, unfortunately.
Its 220 miles from where we live to Rosslare, then another 200 from Fishguard to Tiverton
Against 284 via the Holyhead route
But thank you for the suggestion
Unfortunately its a tight schedule But thanks
Basically I was hoping that it could be done in 8 or 9 hours Rather than resorting to tedious mile munching as I did coming back from Porff's funeral at the same venue
Holyhead
Betws-y-Coed
LlanDindrod Wells
Raglan
looks ok, only suggestion is that if you take the A44 at Rhayader thru nantmel and gwystre to crossgates, just 150 yds across the roundabout is a service station with a caff if you need a break, then back to said roundabout and hang aleft down A483 to llan dodd to rejoin your route
