Identify Electric plugs R1200GS
davett
Member
Bourne Lincolnshire
I have just purchased an R1200gsLC I have a couple of plugs I need help identifying if possible thx.
One next to the Sat Nav power feed white plug I guess this could be an additional auxiliary
And one that goes into a blanking rubber grommet near the back of the beak you can see a blue wire in the top of the picture that’s the one I think this could be for spot lights? It does have a spot light switch and the dash displays them on when you press the switch but they are not fitted.
one on beak is outside air temp sensor, white one is I believe for the wonderwheel on left handlebar. I may be wrong regards white one but don't think so.
The normally blanked off plug on the same cable as the satnav connector is an audio output from the NAV V/VI and is used to connect to the audio systems on the RT. I have been able to get an audio feed from it on my previous GS, and was going to use this to feed a Bluetooth transmitter so the pillion could also hear the satnav while I listened directly via Bluetooth from the NAV, but was stymied when it turned out that this audio is only output when the satnav's own Bluetooth output is disabled.
I believe the three connections on the other connector provide both power and a data link to the bike's systems, so no separate connector is needed for wonderwheel interaction with the NAV.
