Indicators
g.s.john
Getting old aint fer pussies
slade green kent
07 1200, my indicators are self cancelling more the left at motorway speed so i am having hold the button, at low speed or waiting to turn at lights they work normally.
I think vibration is the culprit i have sprayed some switch cleaner in the switches and will try that tomorrow is there any thing else i can do short of replacing the switch units?
You realise the indicators are self-cancelling above walking speed by design John?
When stopped in a traffic queue they stay on but once rolling they should cancel after about 12 flashes. (On a motorway at 70mph you typically need to remake the left indicator for an exit slipway at the 100 yard marker.)
I believe that dealers can tweak the cancel times in software, perhaps a previous owner has had it adjusted ( assuming you haven't owned it from new)?
If it is definitely the switchgear at fault, do a forum search as I'm sure some folks had a problem with the rubber switch membranes in the past and somebody found a solution IIRC.
Yes dealers can alter it, or switch the auto-cancel function off altogether, on some years models at least, but it's a distance setting, not a timed function IIRC.
Yes dealers can alter the distance. In my opinion they switch off far too early. Especially when turning right. JJH
That is precisely what they are doing so working normally have remake the signal at the 100 mtr board on the motorway thanks for the prompt reply's gents.
