Injector Pipe issues
Welshman
Johannesburg
Puting a new clutch in, I found this issue on my injector pipes, yes I am heavy handed, I broke the one? But the one next to it shows "pitting" I had high consumption and fuel staining top of the gearbox, so I think it may have been spraying high pressure fuel very finely? Anybody seen it before?
Looking again, the regulator body has wear and a flat spot it was rubbing on the airbox I guess
I reckon it's just you being heavy handed.
You would probably have caught fire if that had been there a while, especially if it's on the high pressure side.
I've got those same stains on my gearbox - from a small spill a few years ago. bloody quickfit o ring.
Probably, should take beer fridge out of the garage:beer:
I'd be replacing those cracked pipes; they'll only fail sooner or later, and of course you don't need OEM parts unless you are concerned about having OEM grommets.
Heat related stress I reckon.
