Inside a Streetpilot 2720
Aidan1150
Nice but unfortunate husband.
Moderator
Moderator
South Armagh, Ireland
My trusty 2720 started acting up on Sunday and even after a master reset the problem was still there. It had the same symptoms that Bumpkin posted about here. As the unit is no longer supported by Garmin I decided I had nothing to lose by taking it apart to see if I could fix it myself.
I set the GPS on a tea towel to stop it skidding about on the table and damaging itself.
There are 7 screws in the back of the unit.
With all the screws removed hinge the adjustable bracket back out of the way
Gently split the unit open and this is what you see inside
Carefully lift the antennae and little silver plate up and back out of the way
There are three little screws holding the green circuit board in place and a further four around the edge of the electronics. With hindsight I didn't actually need to remove the circuit board, I could have just loosened the four screws around the side and lifted the innards all out.
Be very careful not to damage the little wires and ribbons which link the various elements
And clean the screen, rubber seal and the inside of the outer shell of the GPS. There was some dust and dirt around the seal and the screen some of it quite gritty.
Set the innards back into the shell and be gentle with the antenna.
All back together again and ready to be closed up. Tighten the srews in the shell as tightly as you can without damaging them
My 2720 is now back working again so the spare 2610 I have can go back into it's box again. :)
It's a very simple job to do yourself and may well save you the price of a costly repair.
So is it just a matter of cleaning the inside of the screen?:)
Essentially that's it Tim. It seems that dirt and grit from gloves etc gets in around the seal between the screen and the bezel. The best way to get it all out and the unit working again is to take it apart.
Aidan, you should have worn an Earth-Strap as the components are very sensitive to static electricity. :blast:blast
Oh sorry, I forgot you've got no hair:D
:eek
I never larfed much at the remark above. ;)
PS
If you lived with herself you wouldn't have any hair either.
