The fact that motorcycles work at all is witchcraft - no one really knows why it works.
Which is why I have a gremlin bell underneath and a pagan Green man badge instead of the BMW badge on the front nose.
Of course you do, if you want to.I tend to ride on the balls as its what I am used to.
Oh, and you don't actually change direction with your feet....it has no effect in the steering process![]()
I always ride on the balls of my feet. The insteps feel I have no control over the bike. It's to the point I can't get in a turn at speed other than with my balls on the pegs.
you should try 90 degree gravel bends to see if it makes a difference
So I dont have to load the outside peg on gravel roads anymoreyou should try 90 degree gravel bends to see if it makes a difference
But what I do know, is that my 'pull' the bike into a corner is much more effective, if i'm weighting the same peg as the pulled bar.
Yup, it's raised the contribution quality immeasurably..... And occupies the minds of the 'Which gloves should I wear' merchants. A selfless act for which we shoud all be grateful.
You're right it does look like big clown feet flapping about...thats all I am going to see now lmaoI ride on the balls of my feet, it gives me a better feel for the bike underneath me.
One of the biggest benefits of weighting pegs (road, not off road .. !) is that it gives you a platform, from which you can lever your bars.
Some peepes push their bars, some pull and I tend to do a mixture of both without really thinking about it. But what I do know, is that my 'pull' the bike into a corner is much more effective, if i'm weighting the same peg as the pulled bar.
So picture a flick flack double bend; left then right. If I weight my right peg and as I weight it I pull the right bar up against the push of my foot ... bang ... the bikes on it's ear in a jiffy. And now, already on its left side, I weight the left peg and haul the left bar up against my foot - almost like putting yer boot on a door frame and pulling that jammed door open. The actual weighting of the pegs itself does bugger all, but it gives me leverage to pull the bars ...
Mr Wapping, you say that you weight the inside peg? For clarity I mean the left peg on a left turn? I believe most people weight the outside peg so that your outside leg is tense and pressed onto the fuel tank as you lean off the inside of the bike. It helps make the connection twixt rider and bike more rigid and stable, the bike feels more settled especially in bumpy corners. What is your logic for weighting the inside peg? Is this a technique you have developed or one that was taught in some kind of training. I find it interesting.![]()
a) I don't use the back brake normally and its safer to stay away from it in the event of an emergency,
Well, that's another contentious topic; Use of the back brake. And though I think linked brakes make it a moot point, on other bikes, particularly without any sort of anti-dive capability, I'd suggest that a little rear brake better balances the bike to go round a corner with stability.
, I have been known to f**k it up occasionally by having misread a corner and have it suddenly tighten up on me. After the initial butt clench and oh shit
Well what a load of crap, to put it bluntly.
I think you will find that if you try to corner a bike just by turning the bars you will fail as you will by simply leaning to one side and keeping the bars straight. The simple fact is that cornering on a motorcycle is a combination of many different acts, some probably done unconsciously.
You ask a racer if he ever weights one footrest to assist in cornering or a quick change of direction.
Some people are natural at cornering effectively and quickly on a motorcycle and some people look unsafe and wobble round like the corner was a threepenny bit, from the reply's I can guess which are which.![]()
