Instep, balls?
I do have a push bike.
I admit its a bit hard for me to tell now as I initiate pretty much all turns with deliberate counter steer on a motorbike, but I believe what I said is what actually happens anyway, It's just not obvious.
I think you're wrong, and I think that's the way a motorbike steers as well.
When you initiate a right turn, the wheel first goes left, the contact patch moves back and to the left causing the bike to lean and turn right.
I guess we will just have to differ then... I know what I do when leaning and I certainly don't start the turn by going in the opposite direction. Remember, this is both hands off the bars. Its really easy to tell on a pushbike - do you have one?
I pay little attention to the science of steering.....It's just something that happens.....though playing deliberately with peg weighting and pushing the opposite bar end to achieve countersteering can be quite surprising and also fulfilling.
FWIW though, I agree with Cookie......and having followed him through the arse end of the twisties in Donegal, me solo on my GSA, with him back in his lardy boy days PLUS a pillion on his GSA, and having to ride faster than I was (at that time) comfortable to do while he made it all look very smooth and natural, I know he can ride :bow
I suspect that a lot of this whole discussion is based on interpretation and semantics, and a rather large amount of people not actually knowing how they get around a corner so smoothly.....so much is going on subconsciously, done as muscle memory and instinct, that it's actually quite hard to isolate a particular technique, and even harder to assign values to it.
I learnt so much from off-road riding on loose surfaces and gravel than I know.....and apart from being shouted at to do what was and still is utterly counter-intuitive in sand (POWER ON!!!!!) I have, I hope, absorbed a lot of it in my road riding.
Explaining it though, well that's a totally different thing :blast
Whatever works, no matter how you explain it, it doesn't matter as long as you are happy and safe in your riding...I suspect many of the experienced riders arguing the toss about certain aspects of forces applied etc are actually doing the same thing, even if it isn't being explained very well :thumb2
Next time you're out on your pushbike just try it... you might be surprised :thumb
Going back to the original question, the very excellent i2imca courses encourage you to ride on the balls of your feet (well right foot anyway) to avoid any panic braking causing both wheels to lock and thus losing all the gyroscopic forces that allow you to keep the bike upright. Less important with ABS and irrelevant for riding gods. But it has got me in the habit anyway and I now find it more comfortable.
They are also very good at explaining and demonstrating the physics of a turning bike (including counter steering, etc.).
I think the post is getting side tracked. It started with a question about the positions of peoples feet when riding, a comment along the lines of "feet have no impact on cornering ". Now I disagreed a weighting the pegs can help immensely when cornering to aid changes of direction. Somebody mentioned the Crainer Curves at Donnington, every racer will be on the balls of his feet weighting first one side then the other to aid the quick change of direction required, yes they will also counter steer, no arguments.In short to say weighting pegs makes no difference is utter rubbish, as to comments that you can't corner without doing it, well I deliberately tried to corner yesterday whilst bimbling round the Dales and I'm convinced you can corner without moving the bars in the opposite direction to the corner. Now when pressing on I will use every technique available to me but I don't press on all th;e time. That's my opinion and I see no reason to change it.
Did you take your hands off the handlebars when you cornered ?
...and until I see someone take a bend by just sliding off the seat with their hands behind their heads...I'll go with the forces being applied to the front wheel being the reason they make it around the bend :thumb
That my friend is a very dangerous belief.
Shifting your weight helps by changing the centre of gravity of the whole package i.e you and the bike. "It does not steer the bike"
Riding on the balls of your feet gives greater feel and eases leverage on the bars. "It does not steer the bike"
The thing that steers the bike is leverage on the bars nothing else.
Steve
Steve
+1 :thumb2
Heres a simple image, basically starting to fall over initiates the turn.
Steve
i steer off road with my feet?
pushing more weight down onto the right foot when standing makes the bike track right so I can hold adverse cambers or get out of channels.
You can steer with your feet, really. It DOES turn the bike
Ummmmmmmmmm !!!!
I do a fair bit of off roading and of course weight pegs on cambers and the like. I'm regularly almost on one foot only - t'other being almost completely off the peg - but for me that's all about grip not steering !
Right foot driving through the peg with almost all my weight through it, high elbows give my leverage on my bars.
For me it goes back to this idea of a platform from which I can get a better input into my bars.
Keith Code gives this analogy;
If you're in the middle of the swimming pool and push out (like a star jump) with feet and arms, not a lot happens - because you're pushing against nothing. But push against the swimming pool wall with your feet .... whoosh ... away you float. That's obvious.
It's all to easy to push your bars with your hands, and in effect just push yourself away from the bars like the middle of the pool. You need a platform from which to push.
I was at brands a few months ago and Murray Hambro, superbike racer, was being interviewed over the tannoy. He is the ex squaddie bi lateral amputee - both legs amputated just below his knee.
http://www.bbc.co.uk/sport/0/motorsport/22265878
In his interview he was talking about his disability and the fact that his biggest disadvantage, was that he couldn't weight his pegs very well in order to pull up on his bars when cornering .
so I say again :D i/ it's speed related - 150's - yep you need to pull those bars like feck to steer ! ii/ weighting pegs gives you a platform from which you can yank that stuck door open.
:ronno
When the Americans turned up for the famous Trans-Atlantic series of match races, the riders of the big US 'muscle bikes' bent the bars, so hard were they twisting (counter-steering) them to turn the bruits on our twisty tracks.
Some great racing, look 'em up on You-boob.
Steve
+ 1
Totally agree .
No it rocks the bike from side to side . And due to secondary precession and friction in the steering head there is a small amount of turn but again that's the effect of counter steering through rocking the bike and effectively moving the handle bars .
So, after hearing all the evidence I decided to take the risky step of trying it both ways. Admittedly, I haven't got my GS with me, but a bikes a bike right?
On my instep:
And balls:
Quite honestly it didnt make an ounce of difference....
A bikes a bike?
Ummmmmm, a Harley's a cruiser with platform foot plates. It probably will make bugger all difference .... :thumb
