Jenkins
I am currently using an Autocomm 300 kit on my 2004 1200GS: hard-wired into the auxillary power outlet behind the left knee. It works brilliantly most of the time, except that sometimes it cuts outs about 30 seconds after starting the engine. It will stay dead for 5 minutes or so and then come back on for 30 seconds and then die again. Turning the bike off and then back on again sometimes helps, but not always.
Has anyone else encountered the same problem, and if so is there a solution?
Hope you can help!
Hope you can help!
