Is my fuel pump dead?
Comfy Old Boots
Dublin
Decided to get the r850r back on the road after two years in the shed. Fuel lines were perished so I replaced them with new pipe ( tnx essjay!!!! )
I attached the pumps incorrectly... Found out... Swapped pipes and she started up ok after a bit of persuasion.
I left her running for a minute or two while putting on my gear and she just suddenly stopped. No pump prime.... Fuse fine.
Did I kill the fuel pump and if so, is there a cheaper option to the BMW pump?
Thanks!
Thanks!
There are really cheap ones I rather went for a Bosch equivalent stil half BMW cost here:beer:
Fuel pump :blast Mine gave up the ghost this morning...never a pretty sight...
Thanks!
There are here...paid less than half price for an alternative.
Before splashing out on new pump etc.
If it has the same type electrical connectors by the rear rhs tank mounting as the 1150's then check the wiring for continuity through this area. the connectors can relax due to disconnecting.
Check the relays under your seat. If your horn is working, then replace the fuel pump relay with the horn one and see if it starts - I think it is the same part.
Then the side stand switch can become faulty.
I have had these issues over the years and each fault stopped the pump from working.
