Is the LC cooling system pressurised ?
SMcGirr
England
When I had to set my bike over on its side, I lost some coolant from the expansion tank as the cap hadn't been put in at the factory. Got it topped up again but think it might have some air at the top of the radiator. If I take the radiator cap off to have a look am I likely to create a problem eg if it's pressurised?
SP
Ensure engine is cool, and slacken cap slowly.
It's pressurised with the heat, to elevate the boiling temp.
Al
All cooling systems are pressurised, water (read coolant) has a higher boiling point when it's under pressure. Your bike would overheat if the system wasn't pressurised.
Thanks for that, I will top it up if need be when it's cold
Ball's Law
The angle of the dangle is inversely proportional to the lust of the thrust, providing the urge remains constant.
Hmm you could be wrong, I currently run waterless coolant and that doesn't pressurize as its boiling point is 180, and I assume the lc is running waterless coolant as such shouldn't pressurize.
There is no warning in the manual about removing the expansion tank cap when the engine is still not, so you could be right.
Stupid comments that might get someone scalded! The majority of combustion engine systems are water based - additives stop corrosion amongst other things & can raise boiling point. The LC IS water based coolant so do not remove the radiator cap when hot unless you fancy a trop to casualty. If you are not fully conversant with the technology / not an engineering type, please do not encourage others to cross over their competence threshold - someone will get hurt at some point
Is there a warning about using water-based coolant? It should be a pretty strong warning.
It can still be be pressurised - even if not water-based.
Al
Al
There is no warning in the manual, I was surprised that there wasn't - maybe an error or maybe it really is not an issue on the LC?????????
Have you read the LC manual? Do you have an LC? P.S. It does not have a radiator cap.
I will keep this simple as you are obviously not too bright!
Yes I have a LC
Yes I am a qualified Engineer
Yes the LC has a radiator cap - take the time to research before shooting from your hip!
Take the O/S winglet off (2x torx inside / 2x torx outside) lift the winglet off to reveal the O/S (off side) radiator. Lo & behold - the silver cap you are looking at is a radiator cap!!! I think you are misunderstanding the difference between the pressurised side of the system & the expansion tank ( black cap)
If you don't know / understand - probably best to shut the F**K up in future
Yes I have a LC
You are obviously a total idiot - the manual says top up via the expansion tank cap - have you read the manual? I repeat there are no warnings in the manual - as usual someone with a little knowledge and even less intelligence trying to shout down others because they assume they know best -try reading the manual, muppet!
Gentleman, gentleman ..... First we need to ascertain one thing -
Does the bike have a Hilltop remap?
