Back on the usual, painful topic.
In this last trip, my ageing XT behaved surprisingly well for the first couple of days. Plotted and followed the routes exactly as expected. No U turn issues.
I praised in on the third day, and it all went to shit.
Now. I think my specific unit might have some issues.
Couple of major issues I encountered this time was the XT feeling phantom taps on the right side of the screen, opening a set of menus and changing screens while riding. This went on for about 45 minutes (and made me jump on the wrong motorway exit
). While this is normal behaviour if it rains, especially by the way my Zumo is mounted, weather was dry and there were no objects interferring on the screen.
After almost having it smashed against a wall, I restarted it and the issue went away for the rest of the trip.
My GoPro battery was flat, so I managed to capture just the tail end of this behaviour, not the "phantom taps". You have to trust me on these.
I've had other minor problems (U turns) that are expected, but also very fucking weird routing where the Zumo started sending me through secondary roads despite the routing settings.
Each time I was crossing a small town it would detour me from the main road... always had to double check.
It also did that thing where you are along a motorway and makes you get out on the ramp and then immediately back in. This means that you have to double check each time it tells you to turn/get off a motorway on transfers.
I do the trick with keeping the track active under the route. At least I have that.
The most annoying was: leaving Porto I had a specific
route to follow. I set it up and it asked if I wanted to be routed at the starting point: yes.
After a few miles of stupid detours I realised that it was taking me via backroads.
I stopped, swore at it for a few minutes, then manually selected the beginning of the intended route by tapping on the map, and in this case, the directions where correct (jump on the motorway to get out of town, etc.)
Video here:
I had a number of restarts/resets when riding.
Now:
I am/was generally fairly happy with the rest, hardware-wise. It's the bugs that make this (for me) a pretty much unreliable product. Each trip there is a bunch of issues. (Other XT 1s and 2s in the group too).
But...
For London/inner city navigation I do use (happily) a Beeline Moto 2 as it navigates better than Garmin inside complex scenarios and it's small and more than enough data on screen. That part is sorted.
If I travel, I generally plan in advance routes and options day per day. Both routes and tracks (tracks for both backup and eventual offroad options).
I do use alternative mapping in some cases, generally off-tarmac.
Usually longer trips look similar to this:
I'd also like to be able to use proximity alerts on waypoints sometimes, for detours, etc. I can do that on the 62c. Not on XT.
When at the end of the day, or end of a specific route, I just direct the XT to the destination being it an hotel saved as a waypoint, or punching in the address manually.
I do keep it connected to the phone for data/address search.
I do not use it to receive/make calls or control the music. Do not care much about that.
Last week I wanted to have a Garmin developer at reach to shout at them for an hour before physically assaulting them... so the most logical outcome of this would be to move away from Garmin as clearly they dropped the ball ages ago on consumer nav... but me not being a logical person... I was considering (and I asked about this before in previous years) to waste some more money on Garmin and switch to a Montana 7x0i with InReach.
I do not generally travel outside Europe, but I found myself often without mobile service offroad in not-so-remote areas (Strata Florida in Wales above all, trails on the Alps in Italy, etc.) and was considering and InReach for a bit of safety. The Montana (i) has it inbuilt and works like a proper Garmin GPS (I have a GPSMap 62c and fairly happy with it) that probably would be better for my intended use.
Apart from the massive costs (Montana + Mount + CN Maps) my question is to people that made a similar step.
I know a few users here have both XT for road use and Montana for more offroad/exploration use, but I'd rather have a single device and also, as above, I consider my XT a fairly unreliable device.
Installing CN Maps is the address search decent?
I can do without the lane assist screens.
Are there any massive and known bugs (like the U turn one on the XT)?
Am I putting myself in a world of pain?
Is the screen readable compared to the XT? I do like to keep my nav in that weird position you see in the videos. Sometimes doesn't help with glare.
I do not want to have a phone affixed to my bars, and also prefer dedicated hardware.
