Thanks to Robh1664, Nin and Howz.
I will send the chips tomorrow will arrive to UK after 1 week.
Best Regards from Greece.
Thanks Alan.
I made perfect stage 7-8-9 and 10 for any situation and for any hardware setup.
I think it is finish my work on BMW boxers bikes.
More torque at all revs of rpms without any problem, little richer fuel, smooth function of engine, and more power and final speed at top end.
For full stock bike, for de-cat system aftermarket exhaust for free air filter and for any hardware mods (camshafts, comsprockets and any more).
Thanks to UKGser forum, to all users for helping.
King Regards from Greece
I can send to any UKGser member chip for free cost., just send me a pm fulll name-address-bike details.
Many thanks.
Chips were sent today to Andrew McGill, John Gowers, Graham Shields and Pablo Michelin.
Will arrive to UK after 1 week, to Australia after 2 weeks.
Edit : Pablo, my next hard work will be on old car's '1990-2003'. Chip for ECU for BMW, Group VW, Peugeot, Citroen and more else.
I will work all the winter on this project.
I work alone, i hope to win.![]()
Hi Roger. It is hard to me to connect by comuter on the bike, i see live the AFR and i made the chip by this way.
As i told, by stable throttle the AFR is always 14,7:1 but on acceleration (when i make richer maps) the AFR is richer for all situations, (open-close loop, sea level, mountains..). So the additional value in to injection maps works fine.
Does not matter the stable throttles, because it is only for a very little time, the AFR is always richer by injection maps.
I made maps for any hardware mods, K/N, de-cat system exhaust, mod cams, sprockets and any other.
The friends who try the versions of chip (stage 7,8,9) can tell about rich or lean fuell.
You may be lucky and the seal remains in place and in one piece. In this case, you could just smear some silicone around the existing seal to get a good fix. Make sure you use a neutral cure silicone NOT an acid cure silicone (acid cure smells similar to vinegar). I don't think you need an electronics grade sealant though others on the forum might have other thoughts.Mine should be arriving over the next few days. Cant wait to fit it. Question, do you have to re silicone the ecu once after you have split it?
