Go on Roger, give us a heads up of the bikes you have messed with and what worked and what didn't...
Especially the bits on the chipped bikes you've had a shot of that didn't get it right...
Here's the latest example of a re-chipped bike:
http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=901409#Post901409
Here is the list of bikes that I've helped other riders install LC-1s on so that we could monitor rolling-road AFR of the bikes, before and after lambda-shifting: R1150, R1100, R1200 and F800. For each of these bikes, a few dozen altogether, we've collected extensive LC-1 and/or GS-911 data, all of which has been freely shared and published. Here is one of the threads:
http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=746671#Post746671.
At this point, I can say with a great deal of confidence and evidence, that how the Motronic and BMSK fuel is now well known.
On the R1100, non-cat configurations, you can re-chip and change timing and fueling at will. A different chip (or coding plug) is needed for gasoline with or without ethanol added.
For R1150 and R1100 with catalytic converters, you can re-chip for spark timing but fueling changes in the Closed Loop parts of the map--where most riding is done and most driveability problems occur--will revert to lambda=1 fueling. It has been measured, it happens.
Right all I want to know after pages and pages of techy stuff,....has anyone put their bike on a rolling road after the new chip fitting,and is the AFR and ign timing correct?
Looking at the blurb,i cant see any evidence of any rolling road testing by john??
My bike is running nicely and I really don't want a holed piston and like.I don't doubt johns technical abilities at all,but neither do I want a bike overfuelling and borewashing,or a bike running lean burning holes in pistons,ive seen the mess it makes firsthand, after rebuilding a fooked 1200 which melted a valve.also I note that rewriting the software on the chip should move the closed loop correction area,ie short term trim and long term trim,i cant see how the ic can reprogram itself back to stock values as the ic only works within certain pre programmed parameters.
Sorry to sound negative,but im a firm believer in doing your homework.
from what I can remember the transfer from short term fuel trim to long term fuel trim takes quite a few drive cycles, anyone know how many?
On a vw polo ive just fixed,it would take about two weeks of daily use for a fault code to re-appear that was emissions based.
I'm tempted to put the bike on a rolling road,note the readings and then swap the chip and go for a re run.
What needs to happen for any chip changes on an r1150, is for the chip designer to stick an LC-1 or equivalent in the exhaust and attach a GS-911 to the Motronic. Then make a hundred hours or so of test rides (different temperature, fuels, loads and altitudes), logging AFR and Motronic data, analyzing and publishing. I have suggested it and offered to help interpret it but it has not happened. The reason given is that the instruments are too costly, however $500 US buys the whole setup. I don't think that's too much to spend if you hope to sell 1,000 chips worth $60K to $100K. And the 1000 bikes are worth a several million dollars--their value should be taken into account too.
I would put one of the chips in my bike, but I've not yet gotten comfortable. The reason is that John has said that he changes three classes of tables, fuel, spark and lambda maps. Since there are no lambda maps, I'm concerned that he is over-writing other, unknown correction factors. I also don't see the point in installing a chip with fueling changes in the Closed Loop area just to prove they don't stick. My feeling is that the chip designer should do that and show the rolling-road results.
Below is an example of the easy to record charts, my first one showing 5 minutes of AFR data. You can see the shifted baseline of 14.1:1 (from stock of 14.7) and the dips in AFR as the Motronic richens the mixture during acceleration. There are many examples I've recorded of what works, what doesn't and how the Motronic fuels that can be found in the thread I referenced above.
