kick starting
(RIP) pastyman
cornwall, england
Did anyone else see on the BBC news last week. They were showing a german worker and how he was affected by the current economic problems. He was going to work on his old airhead and it showed him kick starting it,, Very novel way... On the centre stand. left foot on top of the cylinder head whilst he operated the kick start. couple of kicks and off he went... I tried it in the garage but the whole bike just toppled over... maybe he was lighter than me:aidan
Anyone else tried this method?
I used to kick-start my R75/6. Left it on the centre stand, shuffled it to just before tdc, jumped on the kick-starter and away she went. No problem. :rob
That's more or less what it says in the book :augie
Pastyman :rob you obviously got your centre of ballence wrong :rolleyes:
Did you have to get your wife to help pick the bike up off the floor :D:D:D
Val.
Couple of kicks ?
must be something wrong with it, should only need one kick..........
Apparantly not. IIRC on here some time ago there was a discussion on kickstarting a beemer. first prod to energise the coil then second kick to start it. does work too.:rob
Val.
Cheeky bugger. I know Im a fat:robfart but I suppose umpteen stone standing on the pot was bound to change the cog a bit:augie
I can pick it up though.
Used to start the 60/6 on the center stand.
Now I only use the side stand when kick starting Gertie. :thumb2
i'm getting feckin' OLD !!!:rob:rob
untill a week ago, i kick started my g/s because of a failing battery for months, i went to a rally and kicked it every morning (in the 20 deg. f), there is an art to starting a cold, high compression air head. having one tuned right is also a help, which mine is. gotta watch out for the shifter or your bike will ride off with out you. lol. helps one appreciate the e-button.:aidan
cheers,
jim
cheers,
jim
This reminds me of the Baskerville hall ford ride when I tried and failed to kick start Pastymans R80g/s, after one of his doting son's tried to comprehensively drown it 'and me along with it' :eek:
Evey time I gave it a good swing I caught the gear leaver with me foot :rolleyes:
Didn't try standing on the cylinder head though:augie
must not have the technique yet.
1-3 tries.left foot /sidestand .clutch in ,incase i catch the gear lever:rolleyes:
mind you hurt a bit ,if you try it with sandals on:ymca ,and your ankle hits the frame:blast
mine won't turn over with the clutch in. and you shouldn't be riding with sandals :rob don't even want to think about hitting a bare ankle.:eek:
Well I've had lots of jap 500/600 singles without lecy starts and have had no problems but I'm buggered if I can start my beemer with the k/start. It seems to just move the piston about and inch up the bores per prod. I won't bother to replace the k/start on the next box I get. Waste of space IMHO.
And no I'm not:ymca! I laugh in the face of certain death and tweek the nose of the spindley killer fish, Pah.
Well you see maybe this old boy knew something we dont. It was the way he literally stood on the left hand pot whilst he proded the kickstart that interested me . Usually the problem is that the thing is so high you cant get a good swing. This way it looked dead easy. I,ll have to lose a pound or two and have another go.:augie
Mine does start ok on the sidestand though. Must do the two kick thing though.. ( And it mus,nt be full of Welsh water)
