DavidJames
remember the new R has lower suspension compared to last year.. they quietly swapped it.
According to the KTM website the Adventure R is still higher than the Adventure so is it just lower than previous Adventure R models
According to the KTM website the Adventure R is still higher than the Adventure so is it just lower than previous Adventure R models![]()
Come on Dellis, where are the Photo's of you NEW BIKE>>>>>>> it's 10.20am we are waiting And we want a full write up too
AJ
PS Enjoy your your new bike
AJ
Yes. c'mon. It might be the best day of the year so far but that's no excuse![]()
The SMT is an awsome bike
it certainly is![]()
Just got it home - a pic taken for the folks at work
Quick question for you.
Is the Scottoiler a vacuum model and where did you plumb it into ??
The Scottoiler on my 07 990 is a vacuum type and takes its feed from the blanking plug on the right hand side rear cylinder,i have the KTM one it has the adaptor in the kit,take out the blank screw in the union...simples i would imagine the standard scottoiler kit comes with various unions also......
Cracking looking bike. Hope you enjoy it over the next few years.
Isn't it time you updated the SatNav? Looks ancient....
Very nice indeed Dave and Windy is right, at least buy yourself a 2610![]()
Gentlemen the GPS on my bike is a Garmin 278 far superior to the dumbed down Zumo and I won't be changing it until it packs in
Dave
some tips for you.....
get some clear vinyl and stick it on the panels behind the tank bag straps before the laquer is ruined.
you can get a clear protection kit from crispy designs for about £150 which covers all the panels, if you are going to do it , do it now when the bike is new.
the rear pannier rack will be rubbing on the number plate support so space it out.
the clamps for the crash bars on the frame will rub through and will cut in on the first off road tumble so take them off and use a piece of HD inner tube on the area. CAREFUL ON THE LH SIDE watch you dont cut through the wiring loom when you put the clamp on.
aftermarket small fuse boxes will fit next to the original one.
pop a bit of silicone grease around the starter realy on the RH side bash plate cover as they can get wrecked over time.
the "jump start" +ve post is behind the RH cover also, it has a red rubber cover, this splits and falls off.
im surprised you say the buffeting is about the same as a GS I find it far worse
do UK bikes come with that front reflector?
spare seat cover is about £25 and if it rains you will have a wet arse for the rest of the day as the cover absorbs water
have a look at getting a second fan if the engine temp bothers you
the KTM chain lube gets thrown everywhere and it a PITA to clean off. HG do a can of "profi dry lube" - its great!
I read this just in time, about to order a 990 ADV and some of the little tips of stuff to do to a new bike may save me some hassle in the future.
I'd be interested in the service costs, by PM if you are happy with that ? It may save me money to travel further afield to get it done. Cheers
Dave
