LAMPF warning light
Prawnini
Surbiton, Surrey
I am getting a LAMPF warning when I use any indicator, all LED lights working and does not come up when using hazard lights.
Any thoughts?
Riders Manual Page 31
Low beam headlight
High beam headlight
Parking light
Front turn indicator
DRL faulty
Have you checked that the indicator is actually flashing or that the operation initiates without a pause?
Does the DRL work?
DRL works and all other lights ok, just comes on when using indicators and not at startup?
I had the same problem. If your battery isn't putting out more than 12v you cannot start the bike and creates this type of warning.
Now shows LAMPR and left LED indicators are flashing like crazy when used, and when I turn off the engine the left rear indicator stays on but very dim for a couple of minutes.
Not had any starting issues.
So it turns out that the wiring loom is faulty and the main connector is corroded:eek:
They are replacing it under warranty, I knew I shouldn't have taken it out in the rain.......
I have a 65 plate GSA on loan and I must say the gearbox is much smoother than my 14 plate and the grips are warmer too!
Asked them to look at why it was difficult to find neutral too, turns out its a software update that will be done too...Nice one Vines, very professional.
