Matches and an insurance form
If you can pivot the bike over onto one foot of the centrestand you may be able to get something solid under the other leg such as a plank of wood, repeat the process on the other leg, then may be able to roll the bike off the stand?
Only time I had similar problem when I got the bike stuck in a ditch I did end up putting the bike on its side, dragging it out and then lifting it up from bar end - as others have said it is about technique not strength. Good luck!
Sit on it. Start it. Rev it to around 2k. Put it into gear and drop your arse on the rear of the seat and it'll ride off the stand and spray your neighbour with gravel..
