Hopefully someone can help.
I have replaced the final drive bearing - there was slight movement in the wheel but actually the bearing seemed fine when I took it out and I suspect it might just have been an adjustment in the Pivot Bearings needed. That will teach me to jump straight in!
Anyway, final drive bearing replaced alongside with oil seal. All seemed fine for a couple of short runs but have just ridden from Devon to London and back today and there is a slight leak from the new oil seal. Its coming from the bottom where the seal joins the rotating flange (if that's the right word - its the bit you bolt the wheel to).
I have checked the oil level and it is well up the threads whereas I think it should be at the bottom. I wondered whether this could cause the leak or do I need to look elsewhere?
Any advice welcome as am off to Slovenia on it in a weeks time......
Nick
Nick
