Being on the autism spectrum isn’t helping.
If something isn’t quite right it leads to angiaty anxiety and stress.
How I wish it was different.
Chill out or sell the bike
I bet he really wishes he could....
It will measure from the vertical 52° or 38° from horizontal.Presume the angle is measured from horizontal so you are leaning more on the left.
If it was from the vertical your 52deg would be 38 from horizontal and think you would have been on your backside.![]()
The bike will lean more than you can.
Don’t try it if you have A41s on
Ok!
That’s my problem... mine doesn’t.
Maybe that function was removed from the Nav VI, or are you saying the function is there but it displays a blank?
Well, I thought you'd asked a simple straight forward question but all you seem to be getting is abuse ??
If it's any help I had a 2015 TE and it showed the lean angle on the Nav vI like you are describing. Unless the Rallye was different I would think it should show it unless there's a fault. Maybe have to ask a dealer.
Just re-read your original post, sounds like the lean angle sensor isn’t working, take it to you dealer and ask them to check.
I believe this may be the case, thanks
...I never knew such post ride insight was available - I’m suprised that we’ve not got a 'show us your recorded lean angle' thread
I wonder why that could be![]()
Mine didn't display it on a 2015 GSA![]()
Thought it was a log you could read later going to the my motorcycle part, and I believe you must have ABS Pro to have this enabled.
Yes, last ride info on Nav. Average throttle position, gear changes, brakes applied front & rear etcDo you get any of the bike info screen on your Nav VI? The first 2017 Rallye's didn't come with "Computer Pro" so did not have the additional information available on the Nav.
