Unit has arrived from China, they are surface mount chips.
The first problem on fitting is that the 14mm diameter hole underneath for the locating spigot grommet is actually a 14 x 20 mm slot this allows the unit to pivot on the side mounting rubber bushes by 6mm.
This gives adjustment from too high to way too low and no way of locking it in position.
Perhaps there were parts missing?
Rather than bodging it into place I decided it best to make an adjuster from stainless.
I turned a top hat washer to fit in the slot and give a 3mm bearing face on the grommet, fabricated the rest, welded the washer to the assembly and riveted it to the case.
My other concern is that the plastic lens seems very thin ( if polypropylene this would be fine but I suspect it is cast acrylic or similar).
The front cover does have four holes which are a good fit for M5 rubber expanding bushes so I will make a guard / cover from clear acrylic sheet and black Nylon 66 spacers.
Perhaps I should have ordered the cover offered.
I would be interested to know if others had an adjuster included with the unit especially those that are for sale without the bottom locator.
Will try to post photos later.
