LED rear lights causing "bulb failure" light to stay on
richb77
Newmarket, England
Anyone know how to stop the LED rear lights making the "bulb out" warning lamp stay on?
I know i have to load the circuit to trick the sensor into thinking the correct current is being drawn, but with what and where does this thing go? :confused:
Before doing all that, try turning the ignition on without touching the brakes.
Allow the system to self check for the few seconds as usual and you should be left with just the ABS lights flashing before you move off as normal.
Once you set off they should all go out. Well, that works for me anyway...:nenau
Unless of course you've tried this already..... :nenau :thumb
Mine too - stays on until you move off then it goes out.
