Legend Help!
As the Legend only has 8mb of memory you will be limited to the number of maps you can download. Normally you can only get 3 out of the 4 London ares maps on to the unit, plus a couple of other smaller area ones. I normally put on the NE,SE & NW London maps and the South Essex map, that just about uses up all the available memory in the unit.
All you need to do is connect the unit to the cable, choose the maps you what to down load into it and press the save to unit button.
The Legend is handy if you are out walking, it is nice & small and doesn't chew up the batteries like my Streetpilot III. Good for using on holiday when in strange cities and want to find your hotel again.
AR
