Having looked through most of the posts on lighting I need some advice ...
I want to improve the lighting on my '06 GS (no surprise). I have changed the bulbs to Philips X-treme Power which is an improvement but I want to increase my presence on the road and improve my visibility further. I drive on the motorway and major roads daily, but don't use full beam a great deal.
So....
If I upgrade my dipped beam to HiD this would be an improvement on what I have, but would you recommend upgrading the main beam as well?
I can increase my presence on the road by adding Micro DE's, but won’t these be 'drowned out' by the HiD's, so should I install HiD DE's?
Finally would there be any benefit in adding something like Hella FF50's on top of the above mods?
Is all this possible?
I have both upgraded to HID, but if I could afford to do only one, it would be low beam first, but high beam is worthwile, if you use high beam.
micro DE's work fine and dont get washed out by the low beam, FF50's work well, they widen the beam pattern, which is usefull on unlit country roads, especiall those with bends
I think I'm gonna regret saying that
