Has anybody done this? If so any tips and make of lithium battery used?
I'd check with BMW first to make sure it is compatible.
so long as the battery has the right circuitry built in so that it charges correctly then the bike dont care what battery you use
Direct replacement Lithium ‘vehicle’ batteries contain a Battery Management System (BMS). Such batteries are ‘plug & play’ and the fact that they are Lithium is transparent to the vehicle.Indeed - Lithium's charge with constant voltage like Lead-Acid from my (slightly dated) experience of designing battery chargers BUT require much tighter control of the conditions so either the charger has to be more sophisticated or the batter contain extra charge control circuitry.
I would not expect BMW to give carte-blanche to the choice of Lithium that can be used, so wouldn't risk fitting something that they hadn't recommended, otherwise any claims in the event of fire, damage, fcuk-up etc, etc could well be dismissed.
If have warranty use BMW lithium, so no problem, if out warranty, no cheap but very good.
https://www.antigravitybatteries-uk...ries/antigravity-atz-10-re-start-battery.html
Just went through this. Narrowed my choices to either Anti-gravity, Shorai, NOCO or EarthX. Ruled Anti-gravity off the list because I wanted a Lithium-Iron (LiFe) based battery not a Lithium Ion due to less chance of a thermal runaway.
Ended up with the EarthX and very pleased. It cranks the 1250 the strongest of the three I tried, it also has a sophisticated battery management that allows it to be charged with a regular lead acid type charger, no need to get a lithium specific model. It's rated at 420 PCA (pulse cranking amps), but 7.8 amp hours instead of 4, so loads of reserve, and is the only lithium battery supposedly approved for use in light aircraft. It was also the most expensive at $240.
HHTH
Interesting to see the note about older bikes and possible over voltage.
That would be approved for aircraft use in the US then. Many other countries have different regulations.
I also bought the same battery as Adam a week or so after him.Adam: I know it’s not yet 6 months but I am interested in how that new battery is working for you as I may need to change out my (1150) GS battery soon
