Lot of travel on rear brake pedal
david a hall
glos england
I have had as the above for a while, new pads etc. Bled the back brake last night to change the fluid and there were black bits in it. The bike is 2001 1150 with abs, where does the collective think black bits come from? back brake works but lots of travel. pipe seams to swell just in front of caliper when pedal pressed hard.
Hi David
ITS BLOODY DANGEROUS !
More than likely inside of OEM rubber brake hoses starting to crack up and delaminate.
They can start balooning prior to busting causing excess brake pedal travel. Which it sounds like your symptoms Can cause the brakes to bind on as well.
Just check the brake hose threads on here
Time to swop them ASAP for some new hoses braided stainless lines before things get horribly traumatic
If the backs on the way out the front lines are worth replacing too
Swelling brake lines ...
... is an MoT failure; go to HEL :thumb
Thanks guys appreciate your advice. I will start with changing the line. Any idea where i can get a braided one for it.
E Bay is your friend
Did my 1100 with Goodridge Brake Lines superb kit
Think they cover the non servo 1150 up until 02
Or speak to Motorworks
What a muppet in the vid didn,t point out the balooning rear brake line not far off busting and glaringly obvious coming up like a babys arm
Thanks, I am a good Motor works Customer at the min!! I have spent a bit of time on the West coast in and around bikes, those guys are legends in there own minds and the customers are to blame for all and sundry, any routine wear and tear is customer ignorance!
